Main Forums
Interests
Do-It-Yourself Garage
Power Window Question, need help..
<blockquote data-quote="ylkien" data-source="post: 1679190" data-attributes="member: 13445"><p>Yea. Check the contacts. Should have 6 wires on co-drivers side, and 8 (i think) on drivers side. I don't think the warranty can void if open the door, cause they can't detect it (no sticker, etc). </p><p></p><p>Check & clean the grounding wire if there is any.</p><p></p><p>DIY is the best if you are afraid that your tint might be scratched.</p></blockquote><p></p>
[QUOTE="ylkien, post: 1679190, member: 13445"] Yea. Check the contacts. Should have 6 wires on co-drivers side, and 8 (i think) on drivers side. I don't think the warranty can void if open the door, cause they can't detect it (no sticker, etc). Check & clean the grounding wire if there is any. DIY is the best if you are afraid that your tint might be scratched. [/QUOTE]
Subaru Impreza GC8
R35 Used Titanium Exhaust
r32 v-spec 2?
is there really have this model?
V Spec II Key features were:-
Modified Clutch Assembly.
Brembo Brake calipers.
ETS Program Modified.
Upgraded Wheels and Tyres.
Only 1,303 V Spec II cars were produced in Japan 'to...
Exciting news!!!!
Guys and gals!!
Had an extremely exciting email last night.
I might be in a position to buy a 1994 R32 with RIPS Rb30 bottom end, car was originally built by DUKE in Japan but rebuilt with rb30 at ABBEY in UK...
turbo map sensor
hello people,
i'm looking for a stock map sensor from a stock turbo car.
the pressure input should accept a rubber hose instead of bolting on to intake manifold (like stock 4g13/15 mmc ecu)
i found some from...
Main Forums
Interests
