Car Brands
Car Manufacturers
Perodua
Power Window Problem!
<blockquote data-quote="jerrysiow" data-source="post: 1063984755" data-attributes="member: 127470"><p>Hi all, my myvi is around 3years+ edi. Now is my first time facing power window problem (driver side). The motor of the power window is working fine, will up and down but just it will move and stop and move again. And when it reach the top point or bottom point, it wont stop and keep on hit the car door ( tak tak tak sound) few times then it will stop. Is it the master switch got problem? </p><p></p><p>Appreciate on your reply and concern. Thank you.</p></blockquote><p></p>
[QUOTE="jerrysiow, post: 1063984755, member: 127470"] Hi all, my myvi is around 3years+ edi. Now is my first time facing power window problem (driver side). The motor of the power window is working fine, will up and down but just it will move and stop and move again. And when it reach the top point or bottom point, it wont stop and keep on hit the car door ( tak tak tak sound) few times then it will stop. Is it the master switch got problem? Appreciate on your reply and concern. Thank you. [/QUOTE]
R35 Used Titanium Exhaust
Reanult Alpine A110-50 Concept - Weighs 880kg and Packs a 400bhp Punch!
Inspired...
Is 16 inch sport rim suitable for wira 1.3(M)...?, need opinions............
Guyz,,,, im driving wira aeroback 1.3cc... currently overhaul it and change the piston and clutch 1.6... and upgrade to disk brake too, so my 13 inch sport rim cnt fit it as the disk slightly bigger... so i wanted to...
what the best maintenance for rotary engine
hi to all sifu and otai at this forum....
i under process to buy a car with rotary engine.. the engine code is 12a it's NA engine.. carb.
what i want to know is what is the best...
Car Brands
Car Manufacturers
Perodua
