Main Forums
Car Talk
Car Modification
Please Help: Chamber Kits
<blockquote data-quote="nikolaiski" data-source="post: 1063575756" data-attributes="member: 19467"><p>woah...that's a very B I G tyre size for the merc...it's very normal to have such irregularities.</p><p></p><p>Firstly, if you haven't already done so, get your car aligned properly to equalize the camber for front and rear tyres. Remember the camber numbers. </p><p></p><p>If you've already done that, may I ask how far have you driven since you changed the tyres to have it worn out to such an extent?</p><p></p><p>I suggest reading up on alignment issues:</p><p></p><p>http://www.familycar.com/Alignment.htm</p><p></p><p>So assuming you know EXACTLY the above, examine...which side of the front left tyre is worn out? inside? outside? Examine the other tyres for wear patterns..are they worn out the same way? If not how? Document exactly the wear location for each tyre, and the extent of wear of course.</p><p></p><p>If it appears to be all over the inside and outside of the tyre then you might have an alignment problem on one side and not the camber problem. Too much positive camber means your outside will be worn out, and the general steering feeling is not stable..too negative a camber means the inside will be worn out, but shiok to drive..heh heh..your steering will also feel heavier and not return to the centre as easily as before.</p><p></p><p>Should you alignment be EQUAL, then you're probably going to have to examine your driving habits - are you making more aggressive right turns than left turns? Like that sure ur left front tyre wear out faster, especially that you are on big rims..even faster..haha</p><p></p><p>Anyway, online ALOT of places selling..here are the rear camber arms for your car (you need to scroll down)</p><p></p><p>http://buyit.mercedestuningmag.com/Suspension-and-Steering/Caster-Camber-Kits</p><p></p><p>and the front:</p><p></p><p>http://www.iapdirect.com/product.php?productid=41965</p><p></p><p>with your oversized rims/tyre combos, you should aim to have as FLAT a contact patch as possible when the car is turning and going straight. Obviously, given the caster angle of a merc, this may not be possible..so your alignment mechanic is going to have to be experienced enough to know how to compensate...DO NOT listen to those who anyhow tell you to "buka camber" or "boleh boleh boleh!" to any suggestions...IF there isn't anyone else here to chip in with the agreeable numbers, I suggest running 0 to 0.5 camber for a start and see how the tyre wear rate is like..</p><p></p><p>have fun :D</p></blockquote><p></p>
[QUOTE="nikolaiski, post: 1063575756, member: 19467"] woah...that's a very B I G tyre size for the merc...it's very normal to have such irregularities. Firstly, if you haven't already done so, get your car aligned properly to equalize the camber for front and rear tyres. Remember the camber numbers. If you've already done that, may I ask how far have you driven since you changed the tyres to have it worn out to such an extent? I suggest reading up on alignment issues: http://www.familycar.com/Alignment.htm So assuming you know EXACTLY the above, examine...which side of the front left tyre is worn out? inside? outside? Examine the other tyres for wear patterns..are they worn out the same way? If not how? Document exactly the wear location for each tyre, and the extent of wear of course. If it appears to be all over the inside and outside of the tyre then you might have an alignment problem on one side and not the camber problem. Too much positive camber means your outside will be worn out, and the general steering feeling is not stable..too negative a camber means the inside will be worn out, but shiok to drive..heh heh..your steering will also feel heavier and not return to the centre as easily as before. Should you alignment be EQUAL, then you're probably going to have to examine your driving habits - are you making more aggressive right turns than left turns? Like that sure ur left front tyre wear out faster, especially that you are on big rims..even faster..haha Anyway, online ALOT of places selling..here are the rear camber arms for your car (you need to scroll down) http://buyit.mercedestuningmag.com/Suspension-and-Steering/Caster-Camber-Kits and the front: http://www.iapdirect.com/product.php?productid=41965 with your oversized rims/tyre combos, you should aim to have as FLAT a contact patch as possible when the car is turning and going straight. Obviously, given the caster angle of a merc, this may not be possible..so your alignment mechanic is going to have to be experienced enough to know how to compensate...DO NOT listen to those who anyhow tell you to "buka camber" or "boleh boleh boleh!" to any suggestions...IF there isn't anyone else here to chip in with the agreeable numbers, I suggest running 0 to 0.5 camber for a start and see how the tyre wear rate is like.. have fun :D [/QUOTE]
david tao
air con condensor fin cleaning
wat liquid u guys use? how much ah? where to buy? my aircon not cold still got gas means condensor dirty and i too lazy drive to aircon shop and want to save $$ and learn at the same time
What turbo is this?
I found a turbo with this specs but i dont what type of turbo it is. It looks like a T-66 but the diameter is smaller?
Can anyone tell me?
Thank you
Half Cut Shop in JB
Can anyone tell me where I can find half cut shops in JB area?
Main Forums
Car Talk
Car Modification
