The Marketplace Categories
play station 2
<blockquote data-quote="evoboy" data-source="post: 2450915" data-attributes="member: 4958"><p>location...?</p></blockquote><p></p>
[QUOTE="evoboy, post: 2450915, member: 4958"] location...? [/QUOTE]
Low boost after replace TD03 turbo
Hi All sifu,
I just replace my L7 RHF3 turbo to TD03 turbo, using back the original manifold and down pipe by welding.
Turbo kicks in at ~4000rpm compare to the original RHF3 at 3000rpm.
Problem is, i just can't...
Top 10 Budget Coupe under RM30,000
Here I am again giving out the top 10 lists of vehicles you should consider for...
vr4 220hp ecu
Hi, have these question in mind:
Can this vr4 220HP ecu put into vr4 200hp?
Any advantage gain from this swap?
what is the market price for vr4 220hp ecu alone?
Thanks
play station 2
