E evo_kaki Active Member Senior Member Joined Aug 25, 2009 Messages 47 Points 1,508 Location Kuala Lumpur Dec 18, 2009 #1 Can pivot speed meter X remove speed cut on stock 4G63T engine? pls advise . thx
AD_EG 6,000 RPM Senior Member Joined Apr 5, 2009 Messages 6,324 Points 1,663 Location Ipoh Dec 18, 2009 #2 pivot speed meter X has the speed cut function ...so yes it should be able to remove the speed cut limiter....
E evo_kaki Active Member Senior Member Joined Aug 25, 2009 Messages 47 Points 1,508 Location Kuala Lumpur Dec 18, 2009 #3 AD_EG said: pivot speed meter X has the speed cut function ...so yes it should be able to remove the speed cut limiter.... Click to expand... thanks for your info
AD_EG 6,000 RPM Senior Member Joined Apr 5, 2009 Messages 6,324 Points 1,663 Location Ipoh Dec 18, 2009 #4 your welcome.
