Main Forums
Interests
ICE
phasing
<blockquote data-quote="cacin" data-source="post: 2497192" data-attributes="member: 10222"><p>Sounds are sine wave if seen from an osciloscope. So, a 0 degree or in phase is the correct sine wave. A 180 degree rotation means that if you compare the 2 sine wave, one is up (0degree) while the other is down (180 degree). Go goole for sine waves or look at bcae1.com.</p></blockquote><p></p>
[QUOTE="cacin, post: 2497192, member: 10222"] Sounds are sine wave if seen from an osciloscope. So, a 0 degree or in phase is the correct sine wave. A 180 degree rotation means that if you compare the 2 sine wave, one is up (0degree) while the other is down (180 degree). Go goole for sine waves or look at bcae1.com. [/QUOTE]
R35 Used Titanium Exhaust
Turbo dump pipe outlet diameter
Does anybody know the diameter of the turbo dump pipe outlet? the part that bolts up to the front pipe?
Will a 3inch evo front pipe bolt up to it?
Thanks
DIY installing meters
Hello peeps,
Just need a quick guide here. Currently I have 2 aftermarket meters installed in my car which is tapped to the same power source from the ignition if I'm not mistaken. Will it be ok if I add another...
Smart and Extreme 350z's - Must SEE!
Very nicely done...though the red one's GT wing looks like can be used to hang clothes...but nice...done by...
www.nitro.com.my
sn964444
Main Forums
Interests
ICE
phasing
