Main Forums
Car Talk
Car Modification
PCD Conversion 100 to 114
<blockquote data-quote="shiroitenshi" data-source="post: 1323073" data-attributes="member: 27518"><p>The worry about vibration is from improper machining of the bearing holes, since the bearings for the 5 lugs are bigger as far as I know. And even if the bearing holes are slightly off-centre, you will experience vibration.</p><p></p><p>For mine, I got the knuckles of an EK9, including the tie rods, as I had the same concern about improper machining. I think this is the ultimate way to address your concerns.</p><p></p><p>I think integra knuckles will fit yours without problems.. Too bad I sold my last set off to my cousin already.</p></blockquote><p></p>
[QUOTE="shiroitenshi, post: 1323073, member: 27518"] The worry about vibration is from improper machining of the bearing holes, since the bearings for the 5 lugs are bigger as far as I know. And even if the bearing holes are slightly off-centre, you will experience vibration. For mine, I got the knuckles of an EK9, including the tie rods, as I had the same concern about improper machining. I think this is the ultimate way to address your concerns. I think integra knuckles will fit yours without problems.. Too bad I sold my last set off to my cousin already. [/QUOTE]
motec advice
hi all members zth .want ask who can install and setup motec in malaysia ? how about cost install and setup for mitsubishi engine.any member can advice me.thank all zth members.
I need an advice
Hello everybody
I have a...
BOV questions
hey...wat i know is that BO sounds are made when the accelerator pedal is let go rite?not when u the gear is changed rite?
and wat is a boost leak?
Main Forums
Car Talk
Car Modification
