Main Forums
Car Talk
Car Detailing Forums
Painting The Engine Head Cover
<blockquote data-quote="ruff36" data-source="post: 2035719" data-attributes="member: 42788"><p>I oso used to DIY my rocker cover too..using can spray.</p><p></p><p>After took it out i clean it using handgrinder cup brush</p><p>to make sure the surface is smooth(bcoz the rocker was</p><p>a casting).Wash it out using thinner & soap to remove the oil</p><p>& dry it out.</p><p></p><p>To make a good metallic result u can use white or metallic base</p><p>spray 1st 4 several time b4 u spray next layer color of ur choice.</p><p>Finally get a clear coat to finish up the step.</p><p></p><p>Rembr,when started to spray new next layer make sure the </p><p>1st layer is really dry.Patient gain a good result.</p><p></p><p>When time to fix it back,clean out the old sealant frm ur gasket & dont</p><p>4get to wipe clean the block too..apply new gasket sealant."Permatex"</p><p>brand is recommended..put it firmly to the rocker cover and place it back to the </p><p>block.Use opposite way when tightening back all the bolt/nut(up-down-left-right)</p><p></p><p>save a lil bit money..& remember patient gain a gud result..</p></blockquote><p></p>
[QUOTE="ruff36, post: 2035719, member: 42788"] I oso used to DIY my rocker cover too..using can spray. After took it out i clean it using handgrinder cup brush to make sure the surface is smooth(bcoz the rocker was a casting).Wash it out using thinner & soap to remove the oil & dry it out. To make a good metallic result u can use white or metallic base spray 1st 4 several time b4 u spray next layer color of ur choice. Finally get a clear coat to finish up the step. Rembr,when started to spray new next layer make sure the 1st layer is really dry.Patient gain a good result. When time to fix it back,clean out the old sealant frm ur gasket & dont 4get to wipe clean the block too..apply new gasket sealant."Permatex" brand is recommended..put it firmly to the rocker cover and place it back to the block.Use opposite way when tightening back all the bolt/nut(up-down-left-right) save a lil bit money..& remember patient gain a gud result.. [/QUOTE]
david tao
diy a MegaSquirts V2.2 saga lmst, need help..
Hi all,
I'm planning to diy a MegaSquirts V2.2 to my saga lmst year 2004 to convert from carburetor to EFI system.The question is the throttle body,injectors,all the sensors,fuel pump,distributor,intake manifold...
Going back to SG this weekend..any guys wanna kirim anything...
Zex Nitous
Anyone knows where can find the Zex nitrous dealer?
Main Forums
Car Talk
