Main Forums
General Talk
Oxygen Induction???
<blockquote data-quote="taqu" data-source="post: 336152" data-attributes="member: 7651"><p>Normal air have around 20% oxygen, so that means 500% more oxygen will enter engine if pure oxygen is used. Fuel system have to work 5 times harder than average. Probably the engine will produce 5 times more heat, but u can theoritically gain upto 400-500% more horsepower. Can normal engine withstands 5 times more oxygen, or if compare to turbo, can normal engine withstands 4 bar boost?</p></blockquote><p></p>
[QUOTE="taqu, post: 336152, member: 7651"] Normal air have around 20% oxygen, so that means 500% more oxygen will enter engine if pure oxygen is used. Fuel system have to work 5 times harder than average. Probably the engine will produce 5 times more heat, but u can theoritically gain upto 400-500% more horsepower. Can normal engine withstands 5 times more oxygen, or if compare to turbo, can normal engine withstands 4 bar boost? [/QUOTE]
R35 Used Titanium Exhaust
Power FC and FC Hako
Hi guys,
wanted to ask if anyone using FC hako to connect to the power fc? And if any of you attempted to tune your power FC with just the commander ?
As i know the functions avail via commander is limited and its...
GTT r34 jerking
hello to all sifu,
before this my car is running 0.8 bar boost, and in gear 3, at 4000 rpm, the car will jerk for about 3-5 second before continue to blast. Then I switch back to stock boost controller, running...
Zex Nitous
Anyone knows where can find the Zex nitrous dealer?
ae92joon
xa[V]ier
Main Forums
General Talk
Oxygen Induction???
