Main Forums
Car Talk
Car Modification
Overhaul
<blockquote data-quote="rattan" data-source="post: 1093416" data-attributes="member: 19339"><p>Top overhaul means you get a new set of pistons or just change the piston ring and cleaning of your valves and inspection of the crankshafts condition.</p><p></p><p>Full overhaul means opening up your whole engine, getting new bearing, new gasket, new piston rings, maybe even pistons, pulley, springs etc etc.</p><p></p><p>It depends on your engine condition itself, a full overhaul will cost you way more then a top overhaul, if your engine is running fine and its eating some black oil, then just get your piston rings replaced. Do not waste much money on overhauling, better go for transplant as it will cost less and you can ge a slightly more powerfull engine.</p></blockquote><p></p>
[QUOTE="rattan, post: 1093416, member: 19339"] Top overhaul means you get a new set of pistons or just change the piston ring and cleaning of your valves and inspection of the crankshafts condition. Full overhaul means opening up your whole engine, getting new bearing, new gasket, new piston rings, maybe even pistons, pulley, springs etc etc. It depends on your engine condition itself, a full overhaul will cost you way more then a top overhaul, if your engine is running fine and its eating some black oil, then just get your piston rings replaced. Do not waste much money on overhauling, better go for transplant as it will cost less and you can ge a slightly more powerfull engine. [/QUOTE]
R35 Used Titanium Exhaust
review on federal 595evo tyres
guys! please review the federal 595evo tyres!!
evo 6.5 aftermarket bushings
hello,
any of u guys had change ur evo 5 or 6 to an aftermarket bushings? teflon or superpro or etc?
how does it feels? how much does it cost with installation? and any recommended workshop to do it?
thanks guys
Free Carwash & Vacuum 23-09-06 Saturday
To all MLOC members,
Receive
FREE
Carwash & Vacuum
from SHINE N SHIELD AUTO PAINT PROTECTION.
Date: 23-09-2006
Time: 10am till 5pm
Map...
sn964444
Main Forums
Car Talk
Car Modification
Overhaul
