Car Brands
Car Manufacturers
Honda
open pod vs drop-in
<blockquote data-quote="Big[V]" data-source="post: 2591728" data-attributes="member: 31224"><p>I'll 2nd to that one. I've tried various setups on my D15B 3 stage CVT ranging from stock piping (with all the resonators blinded off) to short ram, and from stock to slightly bigger piping. Though it may not apply to all cars but for my D15B at least, stock piping + aftermarket drop in performance filter still gives the best butt dyno result. Moreover I've used VAFC to lower the vtec xover pt and it sounds & perform damn lot better with stock piping. I believe also it is due to the stock piping sucking fresh cool charge air rather than direct hot air with the short ram.</p><p></p><p>I believe the previous post noting the corolla losing to the civic is partially due to heat as well though not by much.</p></blockquote><p></p>
[QUOTE="Big[V], post: 2591728, member: 31224"] I'll 2nd to that one. I've tried various setups on my D15B 3 stage CVT ranging from stock piping (with all the resonators blinded off) to short ram, and from stock to slightly bigger piping. Though it may not apply to all cars but for my D15B at least, stock piping + aftermarket drop in performance filter still gives the best butt dyno result. Moreover I've used VAFC to lower the vtec xover pt and it sounds & perform damn lot better with stock piping. I believe also it is due to the stock piping sucking fresh cool charge air rather than direct hot air with the short ram. I believe the previous post noting the corolla losing to the civic is partially due to heat as well though not by much. [/QUOTE]
david tao
Looking for gearbox foreman
Hi guys, i looking for experience foreman to overhaul or fix my nissan sentra n16 AT gearbox in ipoh perak area... Any of you can recommend me which shop is best and affordable. it will appreciate is address are...
Boost drop problem , pls advise .
Hi guys ... I'm running stock evo 6 engine with Greedy Profec-B specII boost controller .
I set my low boost with +30% on de controller , de boost runs up to 1bar and den drop back to 0.8bar .
What can i do to...
New Baby
New Baby - GT45R and more..
Announcing the arrival of our new baby...something for the crazy horsies....hehe...
Garrett's GT45R ( not for the faint hearted..) :X-:
Good for over 800HP...
Car Brands
Car Manufacturers
Honda
open pod vs drop-in
