Main Forums
Interests
Do-It-Yourself Garage
oil temp meter istallatio
<blockquote data-quote="olskool" data-source="post: 330773" data-attributes="member: 8544"><p>why don't you make an additional hole at the sump? coz by replacing it with the oem bolt may cause the sensor to become faulty after numorous amout of oil change. that's what happen to my friends' car...now to buy a sensor you'd have to buy the whole thing again... </p><p></p><p>on the otherhand some enignes comes with the oil temp sensors...so it'd be easy to tap/replace it..</p><p></p><p>hope this info helps :D</p></blockquote><p></p>
[QUOTE="olskool, post: 330773, member: 8544"] why don't you make an additional hole at the sump? coz by replacing it with the oem bolt may cause the sensor to become faulty after numorous amout of oil change. that's what happen to my friends' car...now to buy a sensor you'd have to buy the whole thing again... on the otherhand some enignes comes with the oil temp sensors...so it'd be easy to tap/replace it.. hope this info helps :D [/QUOTE]
fault code P0400 EGR on Mitsubishi airtrek turbo
Hi guys... Any of u guys had this fault code before? I've google'd the it and found it too technical for me.. All I now is that EGR stands for exhaust gas recirculation....
dashboard & window seals
Where can i get a replacement for the black rubber thingy around all the windows....??? mine is really faded and showing bad signs of wear & tear.
2ndly, where can i get a decent looking dasboard and side...
DIY SUPERCHARGER
I plan to install a Nissan March K10 supercharger into my Gen2. Has anyone done such DIY supercharger projects b4?
Main Forums
Interests
