Main Forums
Car Talk
Car Modification
Oil preasure gauge
<blockquote data-quote="pupjoint" data-source="post: 1063833780" data-attributes="member: 52619"><p>i never had any luck with electrical pressure gauges. i have the same issue, pressure drops to zero, but engine is fine. my engine comes with a stock oil switch, the light never comes on, so i know the problem is not with the engine, but the gauge and sender. </p><p></p><p>bear in mind the gauge i used is brand new everything. VDO brand. i have no expeirnece with other brands. </p><p></p><p>next i will try is a mechanical gauge, which i believe is more accurate.</p></blockquote><p></p>
[QUOTE="pupjoint, post: 1063833780, member: 52619"] i never had any luck with electrical pressure gauges. i have the same issue, pressure drops to zero, but engine is fine. my engine comes with a stock oil switch, the light never comes on, so i know the problem is not with the engine, but the gauge and sender. bear in mind the gauge i used is brand new everything. VDO brand. i have no expeirnece with other brands. next i will try is a mechanical gauge, which i believe is more accurate. [/QUOTE]
david tao
VIDEO: Audi Innovates Future e-tron Accoustics!
While Audi...
HCOTD: The Devil's Six in a Lumma suit on Dubs
'(00): This may not be your top of the range M6 or V8 Six, but if you're not looking at burning the local bahns, this creamy 3litre straight 6 version may just do it for you. - in style. Loaded with the necessary...
Need help on smt5 wiring diagram
Any sifu here can give me wiring diagram smt5 for 4g91bot,or place for installation and setting?????Thank........
Main Forums
Car Talk
Car Modification
Oil preasure gauge
