Car Brands
Car Manufacturers
Hyundai
Oil leak at Spark Plug
<blockquote data-quote="HMS" data-source="post: 828056" data-attributes="member: 1760"><p>IK22 have much better respond than IK20. Can feel the difference a when u rev the engine time, the rpm climbs much faster and provide better power.</p><p></p><p>Reason behind, heat range 7 plugs absorb more heat away from the combustion chamber, thus its good to have cooler internals to reduce component fatique. Cooler also means less prone to misfire during high rpm, also provide stronger and more accurate sparks. Its also very good for high compresion engine, beta engine compression ratio is 10.1 if not mistaken, consider on the high side for NA non vtec non mivec.</p><p></p><p>Too cold is a problem too, spark plugs needs to heat up to about 500 degree to achieve self cleaning of excess carbons. thats y too cold will cos the engine to stall or irregular idling when these carbons cover up the plugs tip. Also will be harmful to the catalytic and o2 as well as ur engine oil getting dirty faster. But what I am trying to find out now is the advance technology of OBD-II ECU, will it know how to compensate the fuel when the o2 detects the changes, cos the ecu are suppose to maintain AF ratio.</p><p></p><p>the by pass really helps, power really comes, worth the trouble to do it. But i wonder y they need to direct engine coolant to the TB in out hot weather country ??? Even now i am thinking how to reduce the heat of the intake manifold, maybe i want to drill a hole and take some temperature measurement of the air inside the manifold so i can design a thing to cool it down to around 20 degree celsius (active cooling).</p></blockquote><p></p>
[QUOTE="HMS, post: 828056, member: 1760"] IK22 have much better respond than IK20. Can feel the difference a when u rev the engine time, the rpm climbs much faster and provide better power. Reason behind, heat range 7 plugs absorb more heat away from the combustion chamber, thus its good to have cooler internals to reduce component fatique. Cooler also means less prone to misfire during high rpm, also provide stronger and more accurate sparks. Its also very good for high compresion engine, beta engine compression ratio is 10.1 if not mistaken, consider on the high side for NA non vtec non mivec. Too cold is a problem too, spark plugs needs to heat up to about 500 degree to achieve self cleaning of excess carbons. thats y too cold will cos the engine to stall or irregular idling when these carbons cover up the plugs tip. Also will be harmful to the catalytic and o2 as well as ur engine oil getting dirty faster. But what I am trying to find out now is the advance technology of OBD-II ECU, will it know how to compensate the fuel when the o2 detects the changes, cos the ecu are suppose to maintain AF ratio. the by pass really helps, power really comes, worth the trouble to do it. But i wonder y they need to direct engine coolant to the TB in out hot weather country ??? Even now i am thinking how to reduce the heat of the intake manifold, maybe i want to drill a hole and take some temperature measurement of the air inside the manifold so i can design a thing to cool it down to around 20 degree celsius (active cooling). [/QUOTE]
david tao
R33 Gts headlamp
RX7 550cc injector
hi anyone noe whr i can get RX7 550cc injector?how much would it cost?
D-I-Y turbo timer
I've heard somewhere that u can diy ur turbo time using timer from washing machine,etc.... can aah??? any ideas how???
Car Brands
Car Manufacturers
Hyundai
