Main Forums
General Talk
office pc
<blockquote data-quote="bigboystoys" data-source="post: 140603" data-attributes="member: 5287"><p>if you insist on using winamp, just go and download the winamp lite version, just a basic player, i'm using a higher spec pc than your office pc, and trust me, when i tried using winamp 5.05 my pc lags too when it's changing songs, crap, problems solved with the winamp lite</p><p></p><p></p><p>AND, i'd think your pc is clogged up with too many applications eventhough you don't use the applications at that time, right? what's best is, change all the settings such that programs DON'T load at all when u startup PC, most of the programs have this options</p><p></p><p></p><p>next, ensure under Start.. Programs.. Startup ... there's nothing in the Startup folder, if there's anything, just delete them, it won't affect the programs, those are just shortcut links.. </p><p></p><p>you can check what softwares have been loaded by just pressing Ctrl-Alt-Del, and check the Task Manager</p><p></p><p>finally if you're still stuck with some programs that couldn't be 'switched off' no matter where u search ... (don't attempt if you're not really sure)</p><p>go to Start, Run.. type in 'regedit' Enter</p><p>go to Hkey_local_machine, Software, Microsoft, Windows, Current Version, RunServices</p><p></p><p>at Runservices, delete those entries that refer to certain programs like MSN, Realschedule.. etc.. if in doubt, then just leave them alone</p><p></p><p>note that softwares like Norton Anti Virus, or external firewall programs, sucks up resources big time, u might want to stop these programs from starting up</p><p></p><p></p><p>after you're done with all the 'switching off', if all above permits, you SHOULD only have these 2 things left in the Task Manager, </p><p>1. Explorer</p><p>2. System</p><p></p><p></p><p>it might be helpful also if u try Defragmenting your harddisk, update all the drivers and updates for hardwares and softwares respectively</p><p></p><p></p><p>good luck in tinkering with the pc !!</p><p>PM me if u need help</p></blockquote><p></p>
[QUOTE="bigboystoys, post: 140603, member: 5287"] if you insist on using winamp, just go and download the winamp lite version, just a basic player, i'm using a higher spec pc than your office pc, and trust me, when i tried using winamp 5.05 my pc lags too when it's changing songs, crap, problems solved with the winamp lite AND, i'd think your pc is clogged up with too many applications eventhough you don't use the applications at that time, right? what's best is, change all the settings such that programs DON'T load at all when u startup PC, most of the programs have this options next, ensure under Start.. Programs.. Startup ... there's nothing in the Startup folder, if there's anything, just delete them, it won't affect the programs, those are just shortcut links.. you can check what softwares have been loaded by just pressing Ctrl-Alt-Del, and check the Task Manager finally if you're still stuck with some programs that couldn't be 'switched off' no matter where u search ... (don't attempt if you're not really sure) go to Start, Run.. type in 'regedit' Enter go to Hkey_local_machine, Software, Microsoft, Windows, Current Version, RunServices at Runservices, delete those entries that refer to certain programs like MSN, Realschedule.. etc.. if in doubt, then just leave them alone note that softwares like Norton Anti Virus, or external firewall programs, sucks up resources big time, u might want to stop these programs from starting up after you're done with all the 'switching off', if all above permits, you SHOULD only have these 2 things left in the Task Manager, 1. Explorer 2. System it might be helpful also if u try Defragmenting your harddisk, update all the drivers and updates for hardwares and softwares respectively good luck in tinkering with the pc !! PM me if u need help [/QUOTE]
R35 Used Titanium Exhaust
Sliverstone FTZ RR price.
just wonder this Sliverstone FTZ RR.
Here I saw ppl selling a 15" set for RM300++/pc.
Now in Singapore I saw ppl post up (new) 17" @ SGP600/set...... that is about RM375/pc... WTH!!!!
Some more this tyre is made...
GT-R Birth Place : Nissan Tochigi Plant
NISSAN GT-R is built at NISSAN Tochigi Plant that is located around 100km
north from Tokyo.
You can see unit line for transmission...
Wts Forged 17 Inch Japanese Rims
http://www.zerotohundred.com/newfor...nese-impul-rims-for-rear-wheel-drive-car.html
sn964444
Main Forums
General Talk
office pc
