NGK Power Cable
NGK Power Cable
powerautohauz
((( God Level 30,000 RPM )))
NGK Power Cable
NGK's Power Cable is a performance spark plug cable designed with ultra-low resistance (0.9kW/m). The ultra-low resistance reduces spark energy loss, thereby improving acceleration, delivering smoother idling, and burning fuel cleaner. NGK's patented hyper silicon jacket minimizes voltage leakage, is resistant to heat and chemical corrosion, and it is reliable under extreme conditions. It's the hyper silicon jacket and the ultra-low resistance that allows NGK to maintain the factory diameter wires and provide the performance you crave.
- Ultra Low Resistance Reduces Spark Energy Loss
- Improves Acceleration
- Delivers Smooth Idling
- Improves Fuel Efficiency
- 30% improvement in sparking energy
A stronger spark improves the engine's performance.
NGK Power Cables with variable pitch winding provide a better spark than standard wires with no compromise to noise suppression.
NGK ultra-low resistance cables with hyper silicone jacketing reduce resistance to improve energy flow and limit electro-magnetic interference. Sparking energy is improved 30% over standard wires.
Vehicle Application Availability
- 4G93T/NA
- B-Series DOHC VTEC
- 4AGE 20V
- 4G92 MIVEC
- 4G63T EVO1~3
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
Desmond 017-396 8567
Email us : [email protected]
