Main Forums
Interests
Motorsport Specifics
Autocross & Advanced Driving
Next autokhana event...
<blockquote data-quote="canken2" data-source="post: 537306" data-attributes="member: 2348"><p><strong>KillerB </strong>where are u...</p><p><strong>LanNismo</strong>(novice) needs help, that includes me too;) </p><p></p><p><strong>LanNismo</strong></p><p>In an Autocross it will be driven harder than normal. </p><p>make sure yr car is road worthy, the includes drive shaft and suspensions too, harder absorver setup will reduce bodyroll when taking slaloms and tight turns.</p><p>Bracing helps too, the XX bars, stiffens the whole chassis. Less body flex. nicer when taking corners.</p><p></p><p>Follow KiilerB's Autocross checklist. Practice? me oso need lots of it:p</p></blockquote><p></p>
[QUOTE="canken2, post: 537306, member: 2348"] [b]KillerB [/b]where are u... [b]LanNismo[/b](novice) needs help, that includes me too;) [b]LanNismo[/b] In an Autocross it will be driven harder than normal. make sure yr car is road worthy, the includes drive shaft and suspensions too, harder absorver setup will reduce bodyroll when taking slaloms and tight turns. Bracing helps too, the XX bars, stiffens the whole chassis. Less body flex. nicer when taking corners. Follow KiilerB's Autocross checklist. Practice? me oso need lots of it:p [/QUOTE]
david tao
Where to buy local Evo 8 Spoiler
Where to buy local Evo 8 Spoiler? Anyone got shop to recommend...the best if the centre blade is carbon look ..pls advice..
When is the Photoshoot Session?
Photoshoots
You know guys, i've been thinking.. We should make a photo shoot session during one TT or a fine day.. Been wanting to get good shots for my sig.. And also wallpaper lah. So.. What do you guys...
Xenons
i noticed that my headlights are rather yellowish while other skylines are whitish.
is it a bulb problem? can i just change the bulb without touching other parts? if yes, any ideas?
thanks
Main Forums
Interests
