Main Forums
Interests
ICE
newbie question
<blockquote data-quote="Zenn" data-source="post: 1010582" data-attributes="member: 15503"><p>the lower the setting means the lower the frequencies u allow it to play. example, if it is set at 50hz, it will only play music that is 50Hz and lower only. normally we set it around 50 to 80 thereabouts. just play your normal songs and u can adjust accordingly to what u like. it will sound weak only if your amp isnt powerful enough for the sub & box combination.</p></blockquote><p></p>
[QUOTE="Zenn, post: 1010582, member: 15503"] the lower the setting means the lower the frequencies u allow it to play. example, if it is set at 50hz, it will only play music that is 50Hz and lower only. normally we set it around 50 to 80 thereabouts. just play your normal songs and u can adjust accordingly to what u like. it will sound weak only if your amp isnt powerful enough for the sub & box combination. [/QUOTE]
R35 Used Titanium Exhaust
Proton acquires stake in Renault, Lotus set to be main sponsor
https://www.zerotohundred.com/wp-content/uploads/2010/11/renault-600x400.jpg
Proton is set to buy over Renault’s remaining 25 per cent stake in the Renault Formula One Team with a signing ceremony due this Wednesday...
HPC Sepang Trackday Oct 31st
Anybody would like to joint this event?
Ideal brake pads
Hi guys need help,
My Z's front disc rotor is thinning (non-brembo), and i just bought a brand new dixcel rotor, and looking for an ideal front brake pads to replace them together. Any recommendations in terms of...
Main Forums
Interests
ICE
newbie question
