Main Forums
Interests
ICE
Newbie Question Regarding AMP
<blockquote data-quote="appleyard" data-source="post: 1209007" data-attributes="member: 7751"><p>you need power to move the speaker and with more power will give you better results. </p><p></p><p>The reason you push your volume with those speakers connected to the Hu is that Hu internal amp is only rated between 20 - 23 watt rms and most of the time you push ity until clipping.</p></blockquote><p></p>
[QUOTE="appleyard, post: 1209007, member: 7751"] you need power to move the speaker and with more power will give you better results. The reason you push your volume with those speakers connected to the Hu is that Hu internal amp is only rated between 20 - 23 watt rms and most of the time you push ity until clipping. [/QUOTE]
Advan GT Beyond 19 Civic Type R FK8 FL5 Rim Wheel
TE37 Saga S Plus 18 Civic Type R FL5 FK8
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Contact n address for mike's body shop usj1
Hi all,
Wanna send my car for paint job. Was wondering anyone here hv the shop address n contact no? Thanks
DIY : Internal Firewall Sound Insulation.
Headlight small light
I have just change my headlamp small light to those LED from Michiba. The problem is when I turn it on, one of the headlamp will switch on however after a while it goes off...and then on again....a few seconds later...
Main Forums
Interests
ICE
