New Turbosmart E-Boost Street controller
jinkl
4,000 RPM
Turbosmart e-boost Street (Videos attached)
huhuhu, came thru this annoucement, looks simple and good
Overview: The e-Boost STREET is a brand new electronic boost controller aimed at the street performance market. It features many boost control capabilities found on its big brother – the e-Boost2, continuing the e-Boost tradition of providing class leading boost control, value for money and no nonsense features.
Boost Settings: There are two boost settings – easily selected via the “turn-and-push” button. An external switch can also be used to change between boost groups if required.
Boost correction factor: Many street cars with standard turbo systems suffer from boost drop off at high RPM. The Boost Correction Factor eliminates this problem and is exclusive to the e-Boost family.
Display: An easy-to-read 3-segment display with adjustable brightness can be configured for PSI, KPa, or BAR and will flash when warning of over boost shutdown or rev limit, allowing the unit to be used as a boost gauge, tachometer, or a shift light.
Housing: The unit is housed in a black anodized aluminum case 80mm wide x 25mm high x 95mm deep allowing the unit to be mounted within a _ DIN size opening.
Maximum boost level: 30PSI / 2.05BAR.
Display mode: Live display of Boost or RPM
What’s in the box?
• EBS Control unit
• Wiring loom + installation kit
• Solenoid with mounting bracket
and vacuum nipples
• Vacuum hose and hose clamps
Product: e-Boost STREET boost controller
Part Number: TS-0302-1001
Available: 1st May 2009
teasers....
Video for more info mates......
http://www.youtube.com/watch?v=VIUrpftVe0Y
Re: New Turbosmart E-Boost controller
Hey Jin.. thanx for great write up..
e-Boost STREET was kept under wraps till the recent launch.
We have a few units reaching the shelfs first week of May.. :driver:
RETAIL : RM 1,650 /pc
This is more than sufficient for a mean street car unless someone who are really serious about making big power can opt for the eboost2 45psi version
Bump: This is more than sufficient for a mean street car unless someone who are really serious about making big power can opt for the eboost2 45psi version
e-Boost2 has 40psi and 60psi and ultimate is 120psi... highest rated boost controller in the market.
Bump: e-Boost2 has 40psi and 60psi and ultimate is 120psi... highest rated boost controller in the market.
lotsa hundreds cheaper than eboost2...good luck on marketing this good product! thumbs up!!
E-Boost Street 30psi
New E-Boost Turbosmart for all turbo street user.
This unit easy to use and setting for low and high boost.
Latest Product Release:
e-Boost STREET
Overview:
Boost Settings:
Display:
Housing:
30PSI / 2.05BAR.
Display mode:
Look at http://www.turbosmartonline.com/index.php?id=355 for more info
3rd GearPerformance can inform you for result and price.
Thanks
nice item. but price. wow. heheh bump for this nice item!!!
Bump: nice item. but price. wow. heheh bump for this nice item!!!
