Main Forums
Car Talk
Car Modification
Need Some Advice.. Pls HELP!
<blockquote data-quote="TiBuN" data-source="post: 1051898" data-attributes="member: 2923"><p>Can't help but reply this, technically your car is worth < RM3000, and you spent RM10,000 on restoring it....</p><p></p><p>Unless the car brings sentimental value to you, I don't see the point to continue the restoration....</p><p></p><p>And yes, the white smoke and high consumption means the engine had taken enough beating, it's time to move on.</p><p></p><p>Not my 2 cents.</p></blockquote><p></p>
[QUOTE="TiBuN, post: 1051898, member: 2923"] Can't help but reply this, technically your car is worth < RM3000, and you spent RM10,000 on restoring it.... Unless the car brings sentimental value to you, I don't see the point to continue the restoration.... And yes, the white smoke and high consumption means the engine had taken enough beating, it's time to move on. Not my 2 cents. [/QUOTE]
Starting Problem
Did not start the car many months
. So instal new battery but still cannot start. Upon changing fuel pump, able to start . Its AVS fuel pump. The next morning need to crank numerous times then only can start. Then...
Tesla Model X's Falcon Wing doors explained
http://www.zerotohundred.com/newforums/../wp-content/uploads/2016/07/tesla-model-x-doors-625x380.jpg
The dual-hinged doors on Tesla Model X is like a modern day sophisticated gullwing. For engineering enthusiasts...
how to recognize engine evo4,5 n 6
any forumer can share with me?
engine only not whole of parts such as g.box,turbo n injector.
Main Forums
Car Talk
Car Modification
