Car Brands
Car Manufacturers
Toyota
need info......4AGZE .....MAP SC
<blockquote data-quote="shamburke" data-source="post: 669813" data-attributes="member: 1119"><p>YEP... IF YOU USE THE ORI METER IT WILL ONLY SHOWS 180KM/H</p><p></p><p>BUT YOUR CAR WILL GO BEYOND 180KM/H.....WAY PASS THE 180KM/H MARK....</p><p>SPEEDO MAXED BUT YOUR TROTTLE CAN STILL TEKAN .. UNTIL RPM REACHES 5600RPM....</p><p></p><p>DON'T KNOW THE SPEED THO'......</p><p></p><p>YEP.. DON'T LOWER YOUR CAR.... TO USE AT LEAST 16" IF NOT DRIVE SHAFT WILL "KRO' KRO'"</p><p></p><p>CHEERSSS.....</p></blockquote><p></p>
[QUOTE="shamburke, post: 669813, member: 1119"] YEP... IF YOU USE THE ORI METER IT WILL ONLY SHOWS 180KM/H BUT YOUR CAR WILL GO BEYOND 180KM/H.....WAY PASS THE 180KM/H MARK.... SPEEDO MAXED BUT YOUR TROTTLE CAN STILL TEKAN .. UNTIL RPM REACHES 5600RPM.... DON'T KNOW THE SPEED THO'...... YEP.. DON'T LOWER YOUR CAR.... TO USE AT LEAST 16" IF NOT DRIVE SHAFT WILL "KRO' KRO'" CHEERSSS..... [/QUOTE]
david tao
I need a 2002 Airtrek Turbo Auto TRANSFER CASE
I need a transfer case for this!
Anybody has one?
Airtrek 4g63t Automatic TRANSFER CASE
you can text or whatsapp me 876-360-2675 or just respond here
what is your best tune on pumped fuel?
just doing a survey here. to share do state:
engine :
turbo(if have):
boost pressure(if turbocharged):
management:
Horsepower obtained:
Any additional toyol inside:
(nitrous,methanol/water injection)
i start first...
engine monitoring
bros,
has anybody seen a device that can monitor
oil pres,
oil temp,
water temp,
volt, amps,
vacuum
in 1 package?
buying gauges for each is quite expensive, also worry about idiots stealing.
your input much...
Car Brands
Car Manufacturers
Toyota
