Main Forums
Car Talk
Forced Induction & Engine Management
need help !
<blockquote data-quote="allance" data-source="post: 1063416026" data-attributes="member: 75900"><p>If you accurately adjust the air / fuel ratio that will result in increased horsepower and cleaner burning fuel to help achieve the goal to:proud:</p></blockquote><p></p>
[QUOTE="allance, post: 1063416026, member: 75900"] If you accurately adjust the air / fuel ratio that will result in increased horsepower and cleaner burning fuel to help achieve the goal to:proud: [/QUOTE]
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
original rare Yokohama ADVAN Racing RG3 18x8.5jj...
david tao
~accident repair ~touch up paint
jeff6126
Tyre on front and rear
Hi all, my car is FF, is there any problem if i use different series and brand for front and rear set? eg: 2 x continental, and 2 x toyo.
the reason is my rear set is almost botak, so i plan to use cheaper tyre to...
Hks Super Afr
Hi all,
Wondering if anyone has experienced with this device before, and if it's fine to use higher cc injectors and tune the fueling with this device.
For example, if my engine is currently running with 4 x 365cc...
v6 turbo.
need some help here...im using a twinturbo 6a12tt....
why is the boost always no occurate..?sometimes low sometimes high..??
long time already im trying this problem but still cant..even i make the actuater hose same...
Main Forums
Car Talk
need help !
