Car Clubs
Car Club Categories
The Altezza / IS200 / IS300 Forum
need help!!
<blockquote data-quote="ARSSS" data-source="post: 1960823" data-attributes="member: 34279"><p>You need to check your brake light switch connected to the brake pedal.. if the brake light switch malfunction, the CPU wont send the signal to release the mechanical lock at P position..</p><p></p><p>Normally when the brake pedal switch doest work, your brake light wont lite up.. check this first.</p><p></p><p>I had same prob before with toyota Wish.. I sprayed WD40 at the pedal switch, then it works as normal.</p></blockquote><p></p>
[QUOTE="ARSSS, post: 1960823, member: 34279"] You need to check your brake light switch connected to the brake pedal.. if the brake light switch malfunction, the CPU wont send the signal to release the mechanical lock at P position.. Normally when the brake pedal switch doest work, your brake light wont lite up.. check this first. I had same prob before with toyota Wish.. I sprayed WD40 at the pedal switch, then it works as normal. [/QUOTE]
R35 Used Titanium Exhaust
4g93t GDi conversion to 4g93 GSR
Hi all,
Any workshop to recommend to do this conversion, Thank you
Any one looking for a vented fiber bonnet for ECR33 GTS Series 2 ?
Hi ECR33 GTS Series 2 owners,
Let me know if you are looking for a vented fiber bonnet, I am looking for an original one to swap, this fiber one is light but I prefer the original one, thanks.
Note: Please note this...
R34 4 door
What is the market price for this R34 4 door now day ?
Manual turbo
my wife hate auto even triptronic
used or unregistered also can
Car Clubs
Car Club Categories
need help!!
