Main Forums
Car Talk
Car Modification
Need Help On Car Modifications...
<blockquote data-quote="wildboar" data-source="post: 500376" data-attributes="member: 3487"><p>1. steel braided hoses can be bought at performance parts shops...shud set u back a few hundred bucks...firstly, they are more lasting and dun get hard or crack like ur usual rubber hoses after a few yrs...secondly, bcos they are steel braided, it doesnt expand..same as using steel braided brake hoses...but the non-expanding characteristic doesnt reli play a major advantage here...thirdly, looks cun in ur engine bay..they might contribute to slight cooling properties due to the outer steel material..but negligible if compared to the cooling effects of the radiator itself..</p><p>2. those are the plug cables..</p><p>3. custom made bananas can cost up to RM1k++, depending on type of engine..</p><p></p><p>my 2 cents..</p></blockquote><p></p>
[QUOTE="wildboar, post: 500376, member: 3487"] 1. steel braided hoses can be bought at performance parts shops...shud set u back a few hundred bucks...firstly, they are more lasting and dun get hard or crack like ur usual rubber hoses after a few yrs...secondly, bcos they are steel braided, it doesnt expand..same as using steel braided brake hoses...but the non-expanding characteristic doesnt reli play a major advantage here...thirdly, looks cun in ur engine bay..they might contribute to slight cooling properties due to the outer steel material..but negligible if compared to the cooling effects of the radiator itself.. 2. those are the plug cables.. 3. custom made bananas can cost up to RM1k++, depending on type of engine.. my 2 cents.. [/QUOTE]
Advan GT Beyond 19 Civic Type R FK8 FL5 Rim Wheel
TE37 Saga S Plus 18 Civic Type R FL5 FK8
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
Photoshoot for skyliners
Hye guys!
UPDATED
Some of you may know me (some in person, some just kenal gitu2). I've had this idea (photoshoot) for quite a long time but just had the guts to say it up front...
Carbon number plate
any of u guys using this plate holder?
Skyline Speed Cut Removal
Does anyone in the country have the ability/device to access the Skyline ECU and remove the lines of code for the speed cut in the factory ECU?
Main Forums
Car Talk
Car Modification
