Car Brands
Car Manufacturers
Honda
need help on B16A here...!!!
<blockquote data-quote="testpower" data-source="post: 3242961" data-attributes="member: 43866"><p>b16b piston on b16a block should give higher compression than stock b16b engine. :hmmmm: . i wonder which one is better... get the b16b complete block or just change b16b piston on b16a block...</p><p></p><p>Bump: b16b piston on b16a block should give higher compression than stock b16b engine. :hmmmm: . i wonder which one is better... get the b16b complete block or just change b16b piston on b16a block...</p></blockquote><p></p>
[QUOTE="testpower, post: 3242961, member: 43866"] b16b piston on b16a block should give higher compression than stock b16b engine. :hmmmm: . i wonder which one is better... get the b16b complete block or just change b16b piston on b16a block... Bump: b16b piston on b16a block should give higher compression than stock b16b engine. :hmmmm: . i wonder which one is better... get the b16b complete block or just change b16b piston on b16a block... [/QUOTE]
[GSR_EVO] '96 GSR 1.8 turbo, Jap import, Tiptronic - CM5A
Hi, my engine is CM5A 4G93t(ck)anyone out there
has anyone got any info / pdf manuals either on car / engine /
tiptronic box,
just purchased a fab car and would like more info / details on it,
also, slight...
SR20DET piston or 4AGZE piston
As per title mentioned, which piston you u go for? which got the less weight and which is more heavy duty?
R32 GTR Stuff for Sale
Please view this thread:
http://www.zerotohundred.com/newforums/showthread.php?p=1592869#post1592869
Car Brands
Car Manufacturers
Honda
