Main Forums
Car Talk
Car Modification
need help for my engine...
<blockquote data-quote="rollakid" data-source="post: 1994016" data-attributes="member: 6588"><p>its nothing like vtec system. vtec actually improves low end power, without it you either have to choose high end power or low end power, not both.</p><p></p><p>i dunno much about citroen engine, but if it doesn't have any cam phasing or cam profiling tech, you are pretty much stuck with power in one power band (but you can tune it to your liking).</p><p></p><p>personally i do prefer power on the top, yet got just enough power to move the car at low rpm. cuz when need power just pop it into 2nd gear and all the way whack 7k+rpm.</p></blockquote><p></p>
[QUOTE="rollakid, post: 1994016, member: 6588"] its nothing like vtec system. vtec actually improves low end power, without it you either have to choose high end power or low end power, not both. i dunno much about citroen engine, but if it doesn't have any cam phasing or cam profiling tech, you are pretty much stuck with power in one power band (but you can tune it to your liking). personally i do prefer power on the top, yet got just enough power to move the car at low rpm. cuz when need power just pop it into 2nd gear and all the way whack 7k+rpm. [/QUOTE]
R35 Used Titanium Exhaust
Nismo Z-Tune by Speedhunters.com
Hi Guys,
Just to share the write-up of the Z-Tune from Speedhunters.
http://speedhunters.com/archive/2009/12/20/car-feature-gt-gt-nismo-z-tune.aspx
Check out the 8th photo, "R-Tune hood". Delicious!
FS: Evo Stock Cams, Injector, Turbo
Have the following e6 items for sale. Suitable for Evo 4 engines, Airtrek upgrades.
1. E6 Cams set (RM1000 NETT)
- Intake Cams 256 Duration Degree, Lift 10.0mm
- Exhaust Cams 260 Duration Degree, Lift 9.5mm
Note...
kelisa rpm meter doesnt run...how?
any1 know the reason ???
pls help....
Main Forums
Car Talk
Car Modification
