Main Forums
Car Talk
Forced Induction & Engine Management
Need Help 1JZ-GTE Weird Problem
<blockquote data-quote="RWC turbochargers" data-source="post: 4324033" data-attributes="member: 93048"><p>The thing between air con off and air con on as far as the engine is concerned is the fast idle switch- so i assume the smoking occurs at fast idle? if you fool the fast idle switch/capsule into operating with out the A/C operating does it still smoke?</p><p>What color smoke blue/white (oil burning) or black (excess fuel)?</p><p>Can do a vacuum test on inlet manifold at idle/fast idle?</p><p>has the PCV valve or/and crankcase ventilation system been modified? is this system working?</p><p>Cheers</p><p>RWC turbochargers</p></blockquote><p></p>
[QUOTE="RWC turbochargers, post: 4324033, member: 93048"] The thing between air con off and air con on as far as the engine is concerned is the fast idle switch- so i assume the smoking occurs at fast idle? if you fool the fast idle switch/capsule into operating with out the A/C operating does it still smoke? What color smoke blue/white (oil burning) or black (excess fuel)? Can do a vacuum test on inlet manifold at idle/fast idle? has the PCV valve or/and crankcase ventilation system been modified? is this system working? Cheers RWC turbochargers [/QUOTE]
Lamborghini 50th Anniversary Drive sees the largest Bull gathering in Southeast Asia!
Looking for bigger brake
Hi all sifus,
Newbie here. Just got a 2003 350Z. The ori brakes really look puny in 19 inch rims. Where can I buy bigger brakes? The ori brembos also suitable as I understand they are 4 pot front and 2 pot back. Are...
Replace speedometer cable
any sifu out there knows how to replace/remove the speedometer cable for satria?
mine making a lot of noise when cruising at 110km/h.
i know how to remove the front panel but never try removing the meter console...
Main Forums
Car Talk
