Main Forums
Interests
ICE
Need advice
<blockquote data-quote="artnet" data-source="post: 537963" data-attributes="member: 1742"><p>if the woofer is no longer needed in ur home theather.</p><p>then give it a try in the car.</p><p></p><p>i also using a home audio tweeter in car. 6ohm. running</p><p>on 50watts@4ohm. it sound alright to me. even urge to</p><p>play it with even higher power.</p></blockquote><p></p>
[QUOTE="artnet, post: 537963, member: 1742"] if the woofer is no longer needed in ur home theather. then give it a try in the car. i also using a home audio tweeter in car. 6ohm. running on 50watts@4ohm. it sound alright to me. even urge to play it with even higher power. [/QUOTE]
R35 Used Titanium Exhaust
What is your G's?
I think many has RSM in their cars. What's the G-Force reading during pickup for your car? Care to share?
timing belt tension got looseness while engine hot
any sifus out there can help me..
i got headache to think bout it.my engine is evo4.
automatic dual mode muffler?
Ok,found this article about how to make twin muffler/exhaust system that is consist of s-flow and straight flow at the same time.
but the problem is i dont know where to find the parts and if i can use another part...
Main Forums
Interests
ICE
Need advice
