Car Brands
Car Manufacturers
Perodua
Myvi Console and tail lights problem
<blockquote data-quote="Izso" data-source="post: 1064660994" data-attributes="member: 2429"><p>This sort of shorting is usually because of ground. If you got the power and trigger power right, then check your grounding. Where did you connect that to?</p></blockquote><p></p>
[QUOTE="Izso, post: 1064660994, member: 2429"] This sort of shorting is usually because of ground. If you got the power and trigger power right, then check your grounding. Where did you connect that to? [/QUOTE]
david tao
HELP! Damaged wire inside transmission
Need urgent advice/recommendation.
Some details:
Car: Chery Eastar 2.0
Year Made: 2008
Age of car: 5 yrs
Mileage: 120 000 km
Transmission: PSA DP0
ATF: Elf Renaultmatic D3 Syn
I was doing some maintenance/cleaning...
Other Needs After Turbine Upgrade
Dear all
Am driving Myvi with stock YRV engine at the moment
current set up
stock turbine RHF4 VF20
Exhaust 2in piping at the moment
soon will upgrade to RHF5 VJ20
was wondering that my current 2 inch exhaust pipe...
Care care - Exterior
I'm looking to my fairlady a good facial/spa treatment like any lady deserves
Anyone have a good all-in-one centre to recommend?
Also, I came across this place, Carnuaba Autospa...
Car Brands
Car Manufacturers
Perodua
