Car Brands
Car Manufacturers
Perodua
Myvi air cond problem. Not cold when engine idle.
<blockquote data-quote="pnlim" data-source="post: 1064208809" data-attributes="member: 142711"><p>the myvi when idle not cold the main problem is overheat by compressor pressure.so the normal pressure is no over 250 psi.when the compressor over 250psi is can not cold then can effect the compressor lose the pressure.we suggest need to install one product.this product can sort this problem.you can call this number 016-3368872 MR LIM.</p></blockquote><p></p>
[QUOTE="pnlim, post: 1064208809, member: 142711"] the myvi when idle not cold the main problem is overheat by compressor pressure.so the normal pressure is no over 250 psi.when the compressor over 250psi is can not cold then can effect the compressor lose the pressure.we suggest need to install one product.this product can sort this problem.you can call this number 016-3368872 MR LIM. [/QUOTE]
david tao
900K cars sold: Honda Malaysia wants to give away 9 cars
(WTF) Driver of GTR35 number plate "KV 98"
Attention All Zthians!!!
Item : wilall 10-60w engine oil 10L
place wer u left it : mex highway (sri kembangan RnR)
date/time : 11/03/2010 / 1am
on the stated date...
arias 86mm piston
i have a set new Arias piston for sell ..rm2300
n a set tomei evo4-8 270" cam shalf rm2700 new
n tomei cam pulley rm1100
all brand new....pls call 0124893661 leng
rev enterprise
Car Brands
Car Manufacturers
Perodua
