Main Forums
General Talk
Muffler....
<blockquote data-quote="ABV9750" data-source="post: 1145199" data-attributes="member: 9375"><p>the pop pop sound is actually incomplete combustion that is suppose to end at the mid section.this is how the mid section position/size is very important.sometimes you can see a few car with mode exhaust has a flame at exhaust tip.this is the same scenario.the different is the incomplete combustion is too huge and create flame.</p><p>truely to said.they lost power due to not enought exhaust piping size and length.</p><p>in your case, the mid section is not in correct position or size compare to the exhaust output.if you wanna settle this quit, just change to bigger mid.prefered oval cause it's good in noise reduction.professional N/A tuner normally will trial and error by just install a straight pipe and check the flame ending.then they measure it and install the mid section at flame ending so that the exhaust resonance end up there and create a vacuum at the backside.the wavelength are vary depends on engine output.sometimes it takes a day or more to identified the end flame.worst case of wrong exhaust selection will create a backpressure.this will absolutely add friction to exhaust flow.</p><p>most of our mechanics not knowing this.they're now just selling product rather than consult the best option for us.</p><p>better buy the recommended aftermarket whole set exhaust that has proven good exhaust flow rather that mix combination.</p><p>go to exss or powerzone or din ejos(ulu klang) to get good advise.</p></blockquote><p></p>
[QUOTE="ABV9750, post: 1145199, member: 9375"] the pop pop sound is actually incomplete combustion that is suppose to end at the mid section.this is how the mid section position/size is very important.sometimes you can see a few car with mode exhaust has a flame at exhaust tip.this is the same scenario.the different is the incomplete combustion is too huge and create flame. truely to said.they lost power due to not enought exhaust piping size and length. in your case, the mid section is not in correct position or size compare to the exhaust output.if you wanna settle this quit, just change to bigger mid.prefered oval cause it's good in noise reduction.professional N/A tuner normally will trial and error by just install a straight pipe and check the flame ending.then they measure it and install the mid section at flame ending so that the exhaust resonance end up there and create a vacuum at the backside.the wavelength are vary depends on engine output.sometimes it takes a day or more to identified the end flame.worst case of wrong exhaust selection will create a backpressure.this will absolutely add friction to exhaust flow. most of our mechanics not knowing this.they're now just selling product rather than consult the best option for us. better buy the recommended aftermarket whole set exhaust that has proven good exhaust flow rather that mix combination. go to exss or powerzone or din ejos(ulu klang) to get good advise. [/QUOTE]
Subaru Impreza GC8
R35 Used Titanium Exhaust
the case of idling gone bad again
hi guys...was wondering if u guys cld kindly offer me ur opinions or advices/solutions on wat cld b d problem im facing wiz my car rite now
cut long story short its regards to my car's idling..its x like d usual up...
Planing to buy rx7
hey guys,
I was thinking of getting a second hand rx7..could you guys please give me some advice..as i don't know much about em
first of all it what should i look for when buying a car?
what is the maintenance...
Road Tax
guys,
another question....... wanna know how much is the roadtax for a GTR (RB26DETT) and the RB25DET?
Main Forums
General Talk
Muffler....
