ALL-IN-ONE
(Wideband Controller integrated into the MTX-L gauge housing)
The new Innovate Motorsports Digital MTX Series Air/Fuel Ratio Gauge utilizes the only 100% digital Wideband air/fuel ratio technology on the market! The award-winning patented DirectDigital™ technology we use is faster and more accurate than common “UEGO” gauges and is now more affordable! In addition, the gauge features a water resistant casing, interchangeable faceplates and bezels, and 2 fully programmable linear analog outputs for use with aftermarket engine managements systems and dataloggers!
KEY FEATURES
• The only 100% digital wideband air/fuel ratio technology!
• Water Resistant 52mm (2 1/16”) round dash-mountable casing is perfect for automotive, powersports, marine, and demanding racing applications
• Built-in Direct Digital™ Wideband Controller reduces wiring and simplifies installation (No LC-1 required)
• Wideband O2 Sensor is compatible with all fuel types (Leaded, Unleaded, Diesel, Methanol, E85, etc)
• Ability to calibrate O2 sensor for increased accuracy
• (2) 0-5v fully programmable linear analog outputs for use with engine management systems “closed-loop” and external dataloggers
• Interchangeable faceplates and bezels: Black and silver bezel, black and white faceplates included
• Large digital readout and programmable “Digital Needle” provides the functionality of a needle style gauge with the pinpoint accuracy of a digital display
• Datalog using LogWorks on your PC
• Serial IN and OUT ports allows for easy
loc sek 27 shah alam
call us fo more info
018-2131320/[email protected]
KEY FEATURES
