Main Forums
Car Talk
Forced Induction & Engine Management
MoTec M4 need help
<blockquote data-quote="Acoustic" data-source="post: 1098172" data-attributes="member: 728"><p>Hi Kolo</p><p></p><p>thanks for the reply.</p><p></p><p>STA - no use one, OK!!!! heheheheeh</p><p></p><p>HT - I also know heater.... but how does it work? is it a ground trigger signal or 12v+ trigger signal or whatever????</p><p></p><p>OX+, not the OX signal. </p><p></p><p>The O2 have 4 wires, B, OX, HT, OX+</p><p></p><p>B is already 12V+, HT is suspected to be trigger signal - probably is ground to close-circuit for the B</p><p></p><p>So why still need OX+ ????</p><p></p><p>I don't know ... all suspect only.... that's why asking.</p><p></p><p></p><p></p><p>ISC, is weird also.... real ISCV got 3 pins, RSO, RSC and power supply 12V+ then what is the ISC PIN from the ECU for? it's not even connected to the ISCV ??? makes me confused :( :( :(</p><p></p><p></p><p>You also not sleeping ???? check your email :)</p></blockquote><p></p>
[QUOTE="Acoustic, post: 1098172, member: 728"] Hi Kolo thanks for the reply. STA - no use one, OK!!!! heheheheeh HT - I also know heater.... but how does it work? is it a ground trigger signal or 12v+ trigger signal or whatever???? OX+, not the OX signal. The O2 have 4 wires, B, OX, HT, OX+ B is already 12V+, HT is suspected to be trigger signal - probably is ground to close-circuit for the B So why still need OX+ ???? I don't know ... all suspect only.... that's why asking. ISC, is weird also.... real ISCV got 3 pins, RSO, RSC and power supply 12V+ then what is the ISC PIN from the ECU for? it's not even connected to the ISCV ??? makes me confused :( :( :( You also not sleeping ???? check your email :) [/QUOTE]
M3 GTS and SG Supercars at Traders Hotel KL
These are some pics of SG exotics at Trader's Hotel KL after their Track day at Sepang, mostly clients of Ascendant...
TT Gathering This Friday - 30 March 2007
Hi All,
TT Gathering this friday is ON. Will be looking forward meeting new skyline owners. See you guys there!!!
Date: This Friday, 30 March 2007
Time: 9.30pm - 11.30pm
Venue: Food Court, Sunway.
PM me if you do...
Reverse sensor..
hi sis+bro... i want to ask u al... do our altezza comes with reverse sensor?? mine 1 dont have.. abit sakit kepala when reversing the car... or got any suggestion?
Main Forums
Car Talk
MoTec M4 need help
