Car Brands
Car Manufacturers
Honda
modifying B18C GSR
<blockquote data-quote="TonyChopper" data-source="post: 1145228" data-attributes="member: 13956"><p>My advice... get the type R head full set with cams, valvesprings(rm1500+) & Type R intake manifold full set (rm1200++).. bolt it right on ur block + some settings on the cam by pulleys.. u probably would need a piggyback such as VAFC to fine tune...</p><p></p><p>Or if u on a low budget... can just buy b16a head+intake manifold (altogether below rm1000)... </p><p>Which is what we called a "Poor man's Type R"</p><p>do a mild PNP.. thinner gaskets + b16a piston(below rm100) for higher compressions.. lastly get an aftermarket or Obd2 Type R ecu and that should be enough... As to what u said..."street performance"</p><p>Me and my friend currently running on this setup and the power felt is so much better than using the b18c Sir head.. head job is very important for NA...</p><p></p><p>As to why u should change the head... is bcos b18c Sir is using a dual stage intake manifold which is not as effective as the b16 and 18CR's single stage intake manifold on the High Rpms... Of course there are aftermarket intake manifolds which fits the Sir head... but they cost at least rm1000++</p></blockquote><p></p>
[QUOTE="TonyChopper, post: 1145228, member: 13956"] My advice... get the type R head full set with cams, valvesprings(rm1500+) & Type R intake manifold full set (rm1200++).. bolt it right on ur block + some settings on the cam by pulleys.. u probably would need a piggyback such as VAFC to fine tune... Or if u on a low budget... can just buy b16a head+intake manifold (altogether below rm1000)... Which is what we called a "Poor man's Type R" do a mild PNP.. thinner gaskets + b16a piston(below rm100) for higher compressions.. lastly get an aftermarket or Obd2 Type R ecu and that should be enough... As to what u said..."street performance" Me and my friend currently running on this setup and the power felt is so much better than using the b18c Sir head.. head job is very important for NA... As to why u should change the head... is bcos b18c Sir is using a dual stage intake manifold which is not as effective as the b16 and 18CR's single stage intake manifold on the High Rpms... Of course there are aftermarket intake manifolds which fits the Sir head... but they cost at least rm1000++ [/QUOTE]
Motul Launches 300V, Motul TRD and Sport Motor Oils!
High Lubricant Sdn Bhd launched the new Motul 300V Motorsports Line range, Motul TRD Sports range and introduced the...
how to modify waja front seat ?
hi guys!
anybody know how to modify waja front seat from rotation adjuster to simply slide like normal seat.
This waja seat make me crazy when i want to adjust the angle...look like stupid when u need to rotate they...
proton wira 1.5 efi ecu
who know where can i mod this proton wira ecu? mod or rechip? pls help..
Car Brands
Car Manufacturers
Honda
modifying B18C GSR
