Main Forums
Car Talk
Forced Induction & Engine Management
Microtech tuning
<blockquote data-quote="GEFORCEXTREME" data-source="post: 1064340380" data-attributes="member: 83979"><p>The throttle body, is there a screw that you adjust to prevent the throttle plate from closing tightly shut? Try adjust it a little to open the throttle plate a little to raise idle RPM.</p><p></p><p>Regarding LT10, it should work alright with your setup, just need a good tuner.</p></blockquote><p></p>
[QUOTE="GEFORCEXTREME, post: 1064340380, member: 83979"] The throttle body, is there a screw that you adjust to prevent the throttle plate from closing tightly shut? Try adjust it a little to open the throttle plate a little to raise idle RPM. Regarding LT10, it should work alright with your setup, just need a good tuner. [/QUOTE]
R35 Used Titanium Exhaust
WTA Evo 7 question
1)evo7 using ron95 or 97? or both ?
2)full fuel tank drive in city can go up to how many kms? (how many litre / kms) (full tank $?)
3)maintenance if compare mazda rx8 whice is easy?
4)any place intro get evo7 good...
skyline GTT 2.5
hi all skyline user....
another pop up question on this car.
Previous i post on celica.. asking on opinion...(bad)
about silvia.....(nice)
and now want to ask about skyline..
so i am new be here...
for the time...
Pls Advise - PFC L-Jetro Version.
Hi Sifu's,
is there any additional gadget to convert L-Jetro from AF sensor to Map sensor?
Thanks
Main Forums
Car Talk
Microtech tuning
