Mechanical ABS
Mechanical ABS
supersonicbug
Penang
I have a pair of working order Mechanical ABS for Civic for sale. Pls SMS 0124776061 or call me for details.
can i use it on saga blm?
wat do i need to do ?
how does it work
The mechanical ABS practically install at the outlet of master brake pump. It function as when u depress the brake pedal the hydrolic fluid pressure will be controlled by the mechanical valve in the device which will not allow too much pressure causing the wheel to be jammed.
I believe it can be install in saga blm but is better to check with your mechanic. This device is found in some of the honda civic back in 96/97.
