Main Forums
Interests
ICE
measuring db
<blockquote data-quote="cacin" data-source="post: 2490214" data-attributes="member: 10222"><p>Bro Kippo,</p><p>Thanks. So that's what you mean by mantainance.</p><p>I do understand that all measurement equiptment needs to be calibrated.</p><p>Have you personally tried Room EQ wizard? I am wondering about the way they do their measurement (SPL meter). There was also a setup that uses the Berhinger mic for the TrueRTA setup.</p><p></p><p>So, the point I have to ponder.... do audio shops with RTA or scope calibrate their measuring devices? <img src="https://zerotohundred.com/forums/styles/default/xenforo/smilies/confused.gif" class="smilie" loading="lazy" alt=":confused:" title="Confused :confused:" data-shortname=":confused:" /> </p><p></p><p>All in all, what I can say is I have tried using both but not with good or calibrated measurement devices. I would have to say that the Room EQ wizard is a software that you can use to adjust your EQ in HT systems (car also can). The trueRTA can be used for HT or car audio to see your system response (instead of having an actual RTA). The only reason I am playing with this is for my own knowledge/fun :)</p><p></p><p>Thanks again.</p></blockquote><p></p>
[QUOTE="cacin, post: 2490214, member: 10222"] Bro Kippo, Thanks. So that's what you mean by mantainance. I do understand that all measurement equiptment needs to be calibrated. Have you personally tried Room EQ wizard? I am wondering about the way they do their measurement (SPL meter). There was also a setup that uses the Berhinger mic for the TrueRTA setup. So, the point I have to ponder.... do audio shops with RTA or scope calibrate their measuring devices? :confused: All in all, what I can say is I have tried using both but not with good or calibrated measurement devices. I would have to say that the Room EQ wizard is a software that you can use to adjust your EQ in HT systems (car also can). The trueRTA can be used for HT or car audio to see your system response (instead of having an actual RTA). The only reason I am playing with this is for my own knowledge/fun :) Thanks again. [/QUOTE]
~accident repair ~touch up paint
jeff6126
Universal front bonnet scoop
jeff6126
Mitsubishi Lancer/inspira Evo front bonnet hood
jeff6126
Honda civic fc gtwing spoiler
jeff6126
Mitsubishi Lancer ~Evo front bumper
jeff6126
accident repair spray painting color
jeff6126
Subaru Impreza GC8
The 2009 AGM
To all MLOC members,
First i would like to apologize for the delay due to not enough committees to work on this.. as we promise you guys out there we would try our very best to make it better each year...
Thank you Cruise Power Garage..
Hi fellow MLOCians and forumers...
Just to share...
After 2 weeks of hardwork done by
Cruise Power Garage
...now..it's time to thank for a good work done by
Kit
and his crew...Well, I have to...
vr4 stock ecu fuel and timing map
found from the dsm forums. enjoy!
Main Forums
Interests
ICE
measuring db
