Car Brands
Car Manufacturers
Toyota
Manifold - Ceramic Coating Vs Thermal Wrapping
<blockquote data-quote="sincere1" data-source="post: 3965561"><p>does the manifold releases any fumes or gas at 1st heat up?</p><p></p><p>I dont notice this issue, at 1st heat up, the engine running for 3 minutes (heat enough) then i closed the bonnet and droven away, i dont get any smell each time open the bonnet after that..</p><p></p><p>the hi-temp resistance paint you referred as what i believe the painting same as the purple paint used at Apexi Spiral, the paint will peel off after some times, or i should say after few years..for heat insulation ? let u tell us..</p></blockquote><p></p>
[QUOTE="sincere1, post: 3965561"] does the manifold releases any fumes or gas at 1st heat up? I dont notice this issue, at 1st heat up, the engine running for 3 minutes (heat enough) then i closed the bonnet and droven away, i dont get any smell each time open the bonnet after that.. the hi-temp resistance paint you referred as what i believe the painting same as the purple paint used at Apexi Spiral, the paint will peel off after some times, or i should say after few years..for heat insulation ? let u tell us.. [/QUOTE]
david tao
Mitsubishi Evo7.5 GTA
hey guys,
I'm interested to know more abt mitsubishi GTA...What do you think abt it? Btw, is it hard to do maintenance/expensive? Btw, whats abt the FC? Any ideas?
And also what is the price range for unreg...
[WTB] FD front light cover(passenger side)
Looking for FD passenger side front light cover.
anybody pls pm me or call me at 016-2217111.thank a lot...
DIY Replacing eterna's dashboard light controller
Simple... Just plug and play. Click here -> http://kruger.fotopic.net/c1137728.html
Car Brands
Car Manufacturers
Toyota
