Yu,
You are playing a dangerous game. don't ever use a wire as a fuse for long period. It may melt the whole wire system. A new fuse set will cause you less than to replace the whole wiring.
I saw my new fuse some time ago at my house, & keep to a new place so that I know why I keep, but now I forgot where liau.......
http://img126.imageshack.us/img126/4214/22112006dm4.jpg
maybe buy 1 more new fuse holder loh.
I have use this home make fuse for more than a year.
wah lau...yu..you are definately going dangerous. even the wire as fuse also expose. One slight touch to the body will fry the whole wire and in some cases the battery exploded splashing acid everywhere in the engine bay.
rubber? have not fix on yet, need to cut the hole, oh, this rubber still have in my house, very big, can see every day, hehehehe.....
No problem for water on car battery, if u conected the (+) & (-) in the water, nothing will happen, save on water. Only is I forgot that I take out the rubber (under the bonnet), this can be problem if touch the bonnet!.... must pull down the wire, but I don think can touch the bonnet....
Ya loh, must do some thing ASAP
I'm curruntly using a stock FD ECU. Did CO check and found out my FD is running on very rich side on idle. Did smell some feul during idle but no black smoke thou.... I do have a exhaust temp and on...
yesterday i just install my ground cable....
first is that my car is old..
so originally.. if open lights.. the rpm will drop a bit..
but then.. after i install ground cable, also same.. :(
dono...
