I looked a nice rim doing promotion, but it is 8 lug, i heart that b8 disc brake normally is 5lug, mean tat the rim cannot fit in, is there another brake system that is 4lug onot???................
Yeah right... Most of us using the 4lugs, either TX3 or lantis 1.8 or BPT. Some using the 5lugs from Lantis V6 or BPD. The PCD for 4lugs is 100, while for 5lugs is 114.3.
b8-210 disc brake is better,because much bigger than 180
although it is 5lugs, you can go engineering place to do drill hole pcd 4 lugs
was done by lots of b8 kaki's
if using stock caliper lfrom bf chasis, you can opt vr4 disc just by plug and play...
all conversion are easy...
no fuss..
keep it going,...
i've got my TD06-17C from a local turbo rebuild shop.. but the turbine housing does not seems coming from a TD06-17C(which originally have internal wastegate but mine don't have). recently get my engine started after...
