The Marketplace Categories
Looking for VAFC...functional one
<blockquote data-quote="cobra_motor" data-source="post: 1716089" data-attributes="member: 13539"><p>FIELD SFC MIVEC/VTEC CONTROLLER FOR SALE. VERY FAMOUS IN AMERICA. WITH BEEP SOUND AT SELECTED RPM LIMIT. CALL NOW 016-6906965</p><p></p><p></p><p>CLICK HERE:</p><p></p><p>real picture of the item</p><p>[ATTACH=full]610150[/ATTACH]</p><p></p><p>picture from website</p><p>http://www.inlinefour.com/fielvteccon.html</p><p></p><p></p><p></p><p>SFC Functions</p><p></p><p>Compatible with stock & modified ECU's, and can modify fuel mapping for 8 RPM settings (1000, 2000, 3000, 4000, 5000, 6000, 7000, 8000), and can change the fuel delivery up to 30%, in 1% increments. </p><p>In "Realtime mode," the fuel delivery can be monitored in 100 RPM increments. </p><p>When maximum fuel mapping of the SFC is reached, a (OF) display will appear. </p><p>Can modify fuel settings on the fly, during constant RPM instances.</p><p></p><p></p><p></p><p></p><p>VTEC Functions</p><p></p><p>Can modify the VTEC and/or MIVEC's hi-cam changeover point in 100 RPM intervals. (minimum 2000 RPM) </p><p>When changing over to hi-cam mode, the "HI-CAM" indicator changes from green to red. </p><p>Can modify hi-cam changeover settings on the fly, during constant RPM instances.</p><p>Other</p><p></p><p>Speed limiter removal (certain models excepted) </p><p>Speedometer displays up to 999km. ("Speedometer mode") </p><p>Digital tachometer. ("VTEC mode") </p><p>For racing on the circuit, there is also a buzzer that can be set to shift points or your redline. </p><p>If there is no input for 5 seconds during "Setting mode," it will automatically return to "Realtime Mode." </p><p>Custom wire-harness couplers are sold separately for users who do not want to splice the stock wires.</p><p></p><p></p><p></p><p>rm570 nego</p></blockquote><p></p>
[QUOTE="cobra_motor, post: 1716089, member: 13539"] FIELD SFC MIVEC/VTEC CONTROLLER FOR SALE. VERY FAMOUS IN AMERICA. WITH BEEP SOUND AT SELECTED RPM LIMIT. CALL NOW 016-6906965 CLICK HERE: real picture of the item [ATTACH=full]610150[/ATTACH] picture from website http://www.inlinefour.com/fielvteccon.html SFC Functions Compatible with stock & modified ECU's, and can modify fuel mapping for 8 RPM settings (1000, 2000, 3000, 4000, 5000, 6000, 7000, 8000), and can change the fuel delivery up to 30%, in 1% increments. In "Realtime mode," the fuel delivery can be monitored in 100 RPM increments. When maximum fuel mapping of the SFC is reached, a (OF) display will appear. Can modify fuel settings on the fly, during constant RPM instances. VTEC Functions Can modify the VTEC and/or MIVEC's hi-cam changeover point in 100 RPM intervals. (minimum 2000 RPM) When changing over to hi-cam mode, the "HI-CAM" indicator changes from green to red. Can modify hi-cam changeover settings on the fly, during constant RPM instances. Other Speed limiter removal (certain models excepted) Speedometer displays up to 999km. ("Speedometer mode") Digital tachometer. ("VTEC mode") For racing on the circuit, there is also a buzzer that can be set to shift points or your redline. If there is no input for 5 seconds during "Setting mode," it will automatically return to "Realtime Mode." Custom wire-harness couplers are sold separately for users who do not want to splice the stock wires. rm570 nego [/QUOTE]
david tao
One lap on-board a race bike at the Macau GP shows why it's the best circuit ever
The Guia Circuit plays host to the legendary Macau GP. A location that some say is much more daunting than the already very...
FS: CT9A Evo 7 Parts For Sales!!!
Selling off complete engine of Mitsutbishi Evo 7
item include:
Standard ECU evo 7
Engine Kosong ( Block Piston Complete)
Original TD05 Turbine and Manifold (STOCK)
Air Flow Sensors
Throttle Body
Fuel Rail...
Differentiate on E8 Mr and E8 turbine
Guys,
wht is the special bout this evo8 MR turbine....can anyone give the spec bout this evo8 MR and Evo 8 turbine in term of the size, trim, housing, and in/exducer size...etc...wht i know is only the wastegate...
