The Marketplace Categories
Looking for GReddy BOV Type S
<blockquote data-quote="iman__210" data-source="post: 794849" data-attributes="member: 2729"><p>type s black head is hard to find, the purple ones are easy though based in luck...type r are the hardest...</p></blockquote><p></p>
[QUOTE="iman__210, post: 794849, member: 2729"] type s black head is hard to find, the purple ones are easy though based in luck...type r are the hardest... [/QUOTE]
david tao
WTB GTR dashboard monitor
i m driving a V-Spec, but my monitor start to mulfunction now. i m looking for a replacement, but i do not feel like put DEFI in as i drive around KL much and feel unsafe to use DEFI.
any idea where to get a...
Stock ecu + safc + s-itc = result ?
ok 1st of all we know that when we use fuel piggyback such as safc and fools the ecu with false signal, automatically ignition map will be screwed
now i want to know, can we 'fix' that screwed ignition map using...
DIY wideband monitoring device
You guys like to diy things?
Look here:
http://www.aces.edu/~gparmer/efi/temp/wb/guide.html#circuit%20board
You can monitor the output using a cheap digital voltmeter.
