Main Forums
Car Talk
LockTech Pedal Double Lock Security
<blockquote data-quote="VectorX2" data-source="post: 1063750893" data-attributes="member: 99968"><p>u can try those with GPS tracking...</p><p></p><p>u can actually custom fit a few security measure into ure car... like smart card... pin required startup... but indeed not just 1 solution will help... each of those compliment one another to improve ure security... but at the end of the day depends on ure luck la...</p><p></p><p>and yes the locktech does help in some way... its worthwhile actually...</p><p></p><p>tink what a thief would think... den u able to tink how to prevent them</p></blockquote><p></p>
[QUOTE="VectorX2, post: 1063750893, member: 99968"] u can try those with GPS tracking... u can actually custom fit a few security measure into ure car... like smart card... pin required startup... but indeed not just 1 solution will help... each of those compliment one another to improve ure security... but at the end of the day depends on ure luck la... and yes the locktech does help in some way... its worthwhile actually... tink what a thief would think... den u able to tink how to prevent them [/QUOTE]
2019 AMG GT 63S 4DR touches down Sepang Circuit
wat boost/ignition timing u running?
2jz with 32psi 9200rpm 18deg
MLOCian @ KLIMS 2006
Here's some pics I've taken from our trip to KL International Motor Show last Sun. It was a tiring but exiting day. I've taken more than 100 pics and here's the filtered few that I felt is worth a share..
Sorry for...
Main Forums
Car Talk
