Car Brands
Car Manufacturers
Honda
Local 1.6 Vtec Engine Overheat
<blockquote data-quote="kelflee" data-source="post: 2626336" data-attributes="member: 52158"><p>eh guys, my current EJ also previously hapened overheating for NUMEROUS time (Which last about a year re-occurance) in 2006. Overheating when i open VTEC, or when sesak jalan, or when u're in a rush.....</p><p>first i changed the salur pipe (Which i only change it when it's leaking hot water splashing my whole front lip black water...)</p><p>secondly changed to double layer original radiator from honda serv. center nearby setapak... (And problem still unsolved when VTEC kicked in)</p><p>thirdly, changed the gasket (Or kasket...?) VIOLA!!!!</p><p></p><p>P.R.O.B.L.E.M. I.S. S.O.L.V.E.D. A.N.D. N.O. O.V.E.R.H.E.A.T.I.N.G. S.I.N.C.E. T.H.E.N.!!!</p><p></p><p>kelf</p></blockquote><p></p>
[QUOTE="kelflee, post: 2626336, member: 52158"] eh guys, my current EJ also previously hapened overheating for NUMEROUS time (Which last about a year re-occurance) in 2006. Overheating when i open VTEC, or when sesak jalan, or when u're in a rush..... first i changed the salur pipe (Which i only change it when it's leaking hot water splashing my whole front lip black water...) secondly changed to double layer original radiator from honda serv. center nearby setapak... (And problem still unsolved when VTEC kicked in) thirdly, changed the gasket (Or kasket...?) VIOLA!!!! P.R.O.B.L.E.M. I.S. S.O.L.V.E.D. A.N.D. N.O. O.V.E.R.H.E.A.T.I.N.G. S.I.N.C.E. T.H.E.N.!!! kelf [/QUOTE]
david tao
Reliable 700hp R32?
Just wondering, if someone wanted to have a reliable and fairly drivable r32 with 700hp, what is needed? Let's just say these are the requirements:
- twin turbo setup (not big single)
- locally (Malaysia) available...
intercooler n boost
guyz..wanna ask
if u change ur intercooler
will it affect ur boost reading???
example engine v6TT using ori i/cooler
then change to vr4 i/cooler
will it make the boost higher??
tq tq tq
RPM Tuning
anyone knows how to tune the rpm meter of wira 2004 ....... today i met huakenny go see my car engine ...... see weather go the hole to tune it ...... but cannot find larr ..... maybe the engine diff from the wira...
Car Brands
Car Manufacturers
Honda
