Main Forums
Interests
Do-It-Yourself Garage
leaking all around engine..
<blockquote data-quote="oligokoko" data-source="post: 3040760" data-attributes="member: 64844"><p>check d "licking" from d top (rocker cover, head, sump etc). go from d top till d bottom. frm my exp, if d oil leaks to ur extractor, usually d top part of ur engine (rocker cover gasket / head gasket / camshaft pulley o-ring worn oredi). dun forget 2 check at ur gearbox 2. usually d flywheel oil seal pecah after some time. make sure 2 check what kind of oil tht is leaking (engine oil ker gb oil ker).</p><p></p><p>car difficult 2 start eh. hmm, starter / battery / fuel supply / carb or fuel inj dirty. so many possibilities aa bro. if d cranking sounds rough or funny or weak, it might b ur starter motor</p></blockquote><p></p>
[QUOTE="oligokoko, post: 3040760, member: 64844"] check d "licking" from d top (rocker cover, head, sump etc). go from d top till d bottom. frm my exp, if d oil leaks to ur extractor, usually d top part of ur engine (rocker cover gasket / head gasket / camshaft pulley o-ring worn oredi). dun forget 2 check at ur gearbox 2. usually d flywheel oil seal pecah after some time. make sure 2 check what kind of oil tht is leaking (engine oil ker gb oil ker). car difficult 2 start eh. hmm, starter / battery / fuel supply / carb or fuel inj dirty. so many possibilities aa bro. if d cranking sounds rough or funny or weak, it might b ur starter motor [/QUOTE]
GTR Problem
anyone pls explain to me, i'm having a problem with my r34 gtr, when i'm in 4th gear and above,i try to full press my throttle, suddenly my RPM from 4000 jump and stuck and 6000, and my speed also will stuck around...
wtb Evo8 recon unit
hi,
my fren is looking for recon evo8,unregister preferable.
anyone know which car dealer hv evo8 in stock do let me know
thank alots :)
WTS 17" weds SA-90
Weds SA-90 rims
9jj +20 offset all round
tyres 235/40 front 245/40 rear
PCD 114.3
letting go for
RM3000 with tyres
call/sms 012-2851720 (kazar)
the pics
Main Forums
Interests
