Car Brands
Car Manufacturers
Perodua
L2S brakes has problem after conversion.
<blockquote data-quote="andrew27" data-source="post: 4300650" data-attributes="member: 39804"><p>Gud evening ZTH members, i had this problem with me for quite sometime now...i just did an engine conversion few months back(half-cut wit FR big disc and caliper) and after that my brakes is feeling spongy and hard at times....</p><p>i did brake bleeding a few times but the feel only last afew weeks and then brakes start to feel spongy again</p><p></p><p>regarding the brakes sometimes feeling hard, some said its the one-way valve, changed the whole booster and valve back to my original kancil one still the problem persist. But i guess it is caused by lack of vacuum cos when i pump on the accelerator pedal, the brake pedal will be soft again. </p><p></p><p>Because of this i'm scared to send my car for inspection until now. Is there anyone facing or have faced the same problem like this before? Has anyone tried modifying the brake system to a better one?</p></blockquote><p></p>
[QUOTE="andrew27, post: 4300650, member: 39804"] Gud evening ZTH members, i had this problem with me for quite sometime now...i just did an engine conversion few months back(half-cut wit FR big disc and caliper) and after that my brakes is feeling spongy and hard at times.... i did brake bleeding a few times but the feel only last afew weeks and then brakes start to feel spongy again regarding the brakes sometimes feeling hard, some said its the one-way valve, changed the whole booster and valve back to my original kancil one still the problem persist. But i guess it is caused by lack of vacuum cos when i pump on the accelerator pedal, the brake pedal will be soft again. Because of this i'm scared to send my car for inspection until now. Is there anyone facing or have faced the same problem like this before? Has anyone tried modifying the brake system to a better one? [/QUOTE]
david tao
Another Airtrek Owner from England
I have not long ago acquired a Japanese Import 2002 Airtrek Turbo R.
I was let down badly by the import company failing to advise me about a number of additional costs/elements I needed to factor in, but I have now...
Keen on Airtrek
Hi guys
I am very interested in buying an Airtrek, love the look, driven one and love the feel and the punch it has.
I am currently driving a Colt Plus Ralliart Turbo, which is fine, but want something with more...
Afc neo doesnt have karman signal.
Hi all sifu,
i bought a second hand afc neo..
and i installed it in my evo 3 engine.
so i go to etc-->sensor check..i found out that my karman reading is --
nothing at all..isit normal?cause as i knw evo3 is using...
Car Brands
Car Manufacturers
Perodua
