Car Brands
Car Manufacturers
Daihatsu
L2 throttle sensor
<blockquote data-quote="flamefox850" data-source="post: 245586" data-attributes="member: 140"><p>ahh ok...i know about logic thighy... 1 for ON and 0 for OFF..no fuzzy logic. i notice that when i press the paddle a little (might say 5% as what u said earlier), my engine will accelerate or cruising...or can say it will maintain its speed constantly. but if i release a little ( eg. 4% throttle), the suddenly it will de-accelerate or decreasing in speed..even can hear the exhaust note change to lower bass</p><p></p><p>what i doubt is when i read on internet about other engine with MAP or MAF sensor type, they always have WOT function...that means after 80% or more throttle, it will enter WOT mode and ECU will not going to receive any signal from O2 or ext. temp sensor anymore. it will just order the injector to inject fuel richer than the base map. that's what i read. how about L2 ??</p><p>no WOT mode right ???</p><p></p><p>then if we throw off our O2 or ext temp sensor, our engine will either running too rich or too lean is it ?</p><p></p><p>for 5 button type SAFC (like mine), the 7200rpm setting will only function if we run on WOT mod...how about L2 ?</p></blockquote><p></p>
[QUOTE="flamefox850, post: 245586, member: 140"] ahh ok...i know about logic thighy... 1 for ON and 0 for OFF..no fuzzy logic. i notice that when i press the paddle a little (might say 5% as what u said earlier), my engine will accelerate or cruising...or can say it will maintain its speed constantly. but if i release a little ( eg. 4% throttle), the suddenly it will de-accelerate or decreasing in speed..even can hear the exhaust note change to lower bass what i doubt is when i read on internet about other engine with MAP or MAF sensor type, they always have WOT function...that means after 80% or more throttle, it will enter WOT mode and ECU will not going to receive any signal from O2 or ext. temp sensor anymore. it will just order the injector to inject fuel richer than the base map. that's what i read. how about L2 ?? no WOT mode right ??? then if we throw off our O2 or ext temp sensor, our engine will either running too rich or too lean is it ? for 5 button type SAFC (like mine), the 7200rpm setting will only function if we run on WOT mod...how about L2 ? [/QUOTE]
R35 Used Titanium Exhaust
Picanto technical training manual
This CD talks about in and out of Picanto from body design up to engine parts. Explains each sensor purpose etc. I think most of modern cars are equally equipped with various sensor used in picanto.
This is not...
Mileage Indicator
My mileage indicator doesn't lit up anymore...... any of you faces the same issue before? is it just a L.E.D. fused, or something worse?
i heard from my friend ...
my friend said something abt tht to me today ....
he say there have some turbokits is design for NA engine
the turbokits only can produce out 60hp around 0.4~0.6bar
its come with a big intercooler and turbokits...
Car Brands
Car Manufacturers
Daihatsu
L2 throttle sensor
