Car Brands
Car Manufacturers
Honda
knuckle's question
<blockquote data-quote="crxr" data-source="post: 2531489" data-attributes="member: 322"><p>Not same, bro. Ej6 rotor is 260, ek9/dc2 5lug is 280. Spoon caliper direct bolt on for ek9 with 280, need to cut n modify ej6 knuckle for 260 rotor to fit longer spoon caliper leg.</p></blockquote><p></p>
[QUOTE="crxr, post: 2531489, member: 322"] Not same, bro. Ej6 rotor is 260, ek9/dc2 5lug is 280. Spoon caliper direct bolt on for ek9 with 280, need to cut n modify ej6 knuckle for 260 rotor to fit longer spoon caliper leg. [/QUOTE]
R35 Used Titanium Exhaust
Random Shot: Honda New Sportscar eXperimental (NSX)
Whilst sending my car in for repairs earlier this week, I spotted this pristine looking
NSX
being serviced at a local car service...
Ford Fiesta 1.4 LX- The little hatch that could - Test Driven and Documented
https://www.zerotohundred.com/wp-content/uploads/2011/03/ff31-600x401.jpg
‘It’s more fun to drive a slow car fast than a fast car slow’ goes the saying, and if currently there was a need to fill that position, the...
Blow Off Issue
Dear All,
my case, after install a blowoff on standard piping, when each time i shift gear as normal press full clutch pedal to changing gear.The problem is the rpm drop to zero until engine shut down unless i...
Car Brands
Car Manufacturers
Honda
knuckle's question
