Main Forums
General Talk
kancil 660
<blockquote data-quote="l200turbo" data-source="post: 3349447" data-attributes="member: 62680"><p>yes,open pod filter (hks apexi k&n n others)</p><p>u can get a tulang ikan (in english dont know what valve it called) less than rm 10 n fixed it between ur actuator hose n open the valve a bit until it reach .8 bar (recommend u get a boost meter).</p><p>normal l2 got fuel cut when u exceed 0.8 or .9 bar.</p><p>dont throttle if fuel cut happens,wait for a while n it should return to normal.</p></blockquote><p></p>
[QUOTE="l200turbo, post: 3349447, member: 62680"] yes,open pod filter (hks apexi k&n n others) u can get a tulang ikan (in english dont know what valve it called) less than rm 10 n fixed it between ur actuator hose n open the valve a bit until it reach .8 bar (recommend u get a boost meter). normal l2 got fuel cut when u exceed 0.8 or .9 bar. dont throttle if fuel cut happens,wait for a while n it should return to normal. [/QUOTE]
Advan GT Beyond 19 Civic Type R FK8 FL5 Rim Wheel
TE37 Saga S Plus 18 Civic Type R FL5 FK8
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
New Exige 380 is Lotus' most Extreme Road Car!
There's a new Exige, named the Exige Sport 380. With 375hp and 410Nm on tap, the car is now 30hp and 10Nm up the Exige Sport 350...
Audi A1 TV spot advertisement
https://www.zerotohundred.com/wp-content/uploads/2011/05/audia1.jpg
So Audi Malaysia would most likely launch the new Audi A1 in Malaysia, since it was spotted in Malaysia during a public unveiling in Michael...
Is there any PINKY SKYLINE in Malaysia?
im doing my survey...
from all around malaysia including Sabah & Sarawak..
from R32 to R34...
THANK YOU
Main Forums
General Talk
kancil 660
